RealtoReel
Greetings all –
I’m working on restoring a Heathkit AP-1800 preamp, and am stuck trying to find replacements for two transistors that support the +/- 35 VDC power supply. The original Q703 / Q707 transistors (tested shorted, with resulting PS output voltages too high) are:
Heathkit # Cross Reference #
Q707 417-283 SMO7275 NPN
Q703 417-284 SM62186 PNP
I have tried using 2N3906 (tested HFE =190 @ 5mA) and 2N3905 (tested HFE =163 @ 5mA) transistors for the positive rail, but apparently their gain is wrong, as the resulting output voltage was too low.
All of the other transistors and electrolytic caps have been replaced, and measured voltages reasonably track spec until the collector of Q703 (and emitter of Q704). I have attached the PS schematic and text from Heathkit’s Theory of Operation section.
Does anyone have suggestions for a replacement set, or perhaps what specifications (e.g., gain) I should be searching for?
