Heathkit AR-1500 volume pot. Compatibility with other Heathkit units?
akmfg
Hi, all.
I've got a Heathkit AR-1500 with a bad volume pot. It is a dual 25k ohm with center tap, Heathkit part number 12-112.
I've been unable to source a replacement.
There seem to be some dual volume pots available from some old AA-22 units, and perhaps some other Heathkit units as well, but I'm not sure which of the old Heathkits used pots that would be compatible (electrically and dimensionally) with my AR-1500.
I'd be grateful for any ideas you can offer.
Thanks!
-Matt
Total resistance of a volume pot is not critical. The tap is for the loudness circuit. The AR-15 also uses a 25K pot but mechanical design might be the biggest issue.
I have the same issue with one of my AA-2010 quad amplifiers and I am in the process of attempting a repair of the broken right channel resistance element but I also bought one of these as it appears the elements are physically the same as the ones in my volume control although I haven't removed one yet to verify.
Doug
Sometimes control boards are found on ebay, these contain the four main pots used by both the AR-1500, as well as the AR-1500A.
