I reinstalled the removed components for the sep adj on the multiplexer board, removed the pin 8 to 9 bridge, and reinstalled the MC1305 IC. The pin voltages at the IC read exactly as given in the manual for no stereo output, ie, 11v at pin 6 for no stereo, the other pins as well matching the manual. Running a test for composite stereo output from the AM/FM/IC board, of having a no station hum with the treble turned up all the way, the mono switch makes no difference in the high frequency output, just the same constant volume usual no station buzz or hum. If there had been a change, it might have indicated that there was a composite signal.
Testing between D and E on the board (left and right signal out), with the unit off, and toggling the mono switch, the ohm meter reads13k ohms switch out to 2k ohms switch in. Normal resistance.
I think the NTE722 IC I had is kaput now, as originally, when I first installed it, the pin readings were close to the manual readings for the 1305, with pin 6 reading 11v for no stereo. Later the 722 IC readings became as listed in the earlier email, with pins 10, 11, 12, and 13 reading 4.5v, etc. Must have shorted it somehow. Another one should be arriving n the mail momentarily from a very slow outfit. Should have ordered this one from Mouser as I did the one I just fried. Mouser delivers almost immediately. Good outfit.
I'm beginning that the problems is with the AM-FM-IC board, although as I mentioned before, all the voltage readings for that board are correct, no bad solders, no breaks in the board, no leaky capacitors, and no coils, etc, have been touched, but show continuity as they should.
Well, at least I have good mono FM. AM is ok as usual.
thanks,
Del
