Dig22
Hi,
I recapped Heathkit FM-3. Photos and schematic are below.
It sounds great, but there's a bad humming coming off the output next to the antenna terminals. The other output is clean. I haven't spotted any broken connections but most resistors were way over value so I swapped them. I haven't changed the tubes yet because the voltages are high and I don't want to damage any good tubes. I'm not sure whether or not that should be a real consideration.
On the Tube A, 6X4, Pin 1 was 255, 25v over the higher end of the range. Pin 5 was 238V, 28v over. Pin 6 was 255v, 25V over. Pin 7, 276, 26V over.
And on the 20uf 350V capacitors, one was spot on, one was 37V over.
So where else can I look? Is it a transformer issue? A grounding issue? A bad tube? Have I missed something really obvious? Lastly, the board looks filthy. I'll clean it when I've resolved the issues.
Thanks in advance.
Thanks in advance.
