Kennyg2209
Well-Known Member
I wasn't sure where to post a question about this , but since it's a tube amp I'd post it here . Even though the amp is working fine .
I recently refurbished the signal tracer that I've had for a while . I changed all the caps and resistors that were out of spec . The amp itself is quiet . I had the cap going to the volume pot disconnected and from the volume pot on the amp is quiet . Just a very slight hiss at full volume . When I connect that coupling cap to the probe , I have noise. It's quiet turned down , but pretty noisy getting close to full volume . It's the same with the probe switch on audio or RF. I did clean that switch also. Do these probes pick up that much noise ? I do have about 20mv at 17,500 Hrz noise on my scope without its probe connected to anything . I turned everything off in my shop , but it's still there . When I connect the ground to the tip on the signal tracer probe, it is quiet . If it's the signal tracer probe, Is there a way to modify it to make it quiet ?
Any help would be appreciated . Thanks
KennyG
KennyG
