I picked up a Heathkit PS-4 (same circuit as IP-32) regulated power supply recently to serve as a secondary supply for the @kward Special I'm also putting together. It featured nearly-all original components (including Daystrom-branded GE 6L6GCs) and sort-of-worked; Voltage won't zero-out, voltage adjustments take a fair bit of time to take effect, and voltage starts to oscillate if you try to drop the B+ adjustment pot too quickly.
The original 6BH6 control amplifier tested OK, but I went ahead and swapped it with a known-NOS tube just in case. All of the caps were replaced save one that had been replaced with a Sprague Atom fairly recently. The original 6L6GCs tested weak, so I replaced them with some pre-loved 6L6GCs that previously served as output finals in my Silvertone 1484 but still tested strong-and-close on my Hickok 600A. The 0A2s seem to be perfectly good.
I replaced a couple of out-of-spec resistors, and calibrated the voltmeter movement against my Fluke 115 in both the B+ and C- settings; the original precision resistors are dead on.
Unfortunately, some of the bad behavior still exists, although it's better than it was to begin with. I'm mainly concerned about the responsiveness of the B+ control, and the oscillation.
Poorly-shot iPhone video here: https://www.dropbox.com/s/ma31xo9thzoc2v5/IMG_4884.MOV
I suspect there's a problem in the bleeder network maybe. Or maybe this is to be expected without a "real" load. But the calibration instructions in the manual don't mention adding a load of any sort. Tried hooking up a 13K 10W resistor, supply sags quite a bit (won't go above 300V on the meter) and still oscillates when the voltage is dropped.
Schematic here: http://www.rsp-italy.it/Electronics...Kits/Heathkit PS-4 power supply schematic.pdf
Anyone have suggestions for next steps in the restore / repair process?
