heathkit random pop/thump
Hey, if you're thinking about modding the output anyway, what about DC's EFB? I don't know anything about it, but the guys here say it's great. I'm thinking by doing that mod, or the others we discussed, you will inadvertently get the bad part replaced. Does that make sense?
Another diagnostic tool would be a can of freeze spray since it only does it during warm up, but you have to be really careful with that stuff around tubes. I popped an Amperex 6BQ5 once with a drip of condensate off a RedBull can.:thumbsdn:
thanks for the quick reply! anyway, my wall voltage really likes to fluctuate between 114 and 120. I will read up on DC's EFB and get some more info.
I am not sure how comfortable I am using freeze spray by tubes. I may try it.
I just found some out of spec resistors at the 6u8s and one 470k showing 505k on a 6bq5
Cool, get those old noisy carbon comps out of there. It's my opinion that nothing good can happen by leaving 50 year old CC resistors in these small integrateds. I like carbon films in the direct signal path, and metal film for the power supply. This is not to say that you can't buy good new CC resistors, and they can have their place. I use them every so often in certain spots, but you have to get a bunch of them if you match stuff up channel for channel like I do. With carbon comp, I will go so far as to match them cold, then heat them in the oven for a bit, and re-check. With carbon film, or metal film, I just match and go.
I will go ahead and order new carbon/metal films for it. now for that plate voltage, I don't like it being that high either so is there a way to lower it without using a variac?
A couple ways. You already have slow turn on via the 5AR4 rectifier, so no real need for a CL80 or other type thermistor, and they only drop a small amount. Check your filament voltage and see how close it is to 6.3vac. That will let you know if you need to drop the V before the PT or just adjust the output stage voltage and cathode Rs. Let me get back at ya here on the BP caps, I want to say 100uf but I better double check.
The filaments are at 6.29v so no need to drop before the PT
That's cool, they were just running them hot to squeeze out some power maybe. On the BP caps, 47ufx25v should do. I'm going to dig out my schematic on these so I can make sure I'm giving you correct advice. Or.............I could pull the bottom off mine to check the values and get you a couple pics. I have to eat pizza and go to bed now, but I will pull it out tomorrow after work.
One small mention about the plate voltage, the effective voltage is measured from cathode to plate. If this one has cathode bias resistors, you'd need to subtract the cathode voltage if you are measuring plate to ground. Use that number to calculate plate dissipation. It won't be hugely different, but it will be different. 6bq5's typically run somewhere around 12v on the cathode.
oh okay well I forgot to subtract the 14v but it is still super high. I also measured 377v at the rectifier instead of 390v and 350v at the 6u8s instead of 305v
I tried a 200 ohm high wattage resistor right after the rectifier and got the plate down to 335 which is high but made the amp sound so much less stressed. The 6u8s should last longer at 300v instead of 330 as well.
Another thing I did was made the cathode bypass resistor 120 ohm to run the tubes cooler. I will switch to one resistor and cap per channel, however I tried and managed to red plate some tubes for some reason.
I don't know... Did you de-oxit the tube sockets? Maybe re-tension the tube sockets?
just my .02
Oh, that 33ma you mentioned, is that per tube, or per pair of tubes? If its per-tube, its a smidge light but not too far off book values. If thats for a pair, you're about half of normal. That would account for the overly high B+ if the power supply is not properly loaded.
It was per tube which according to the bias chart I used, is still in the hot range.
Tube sockets have also been cleaned, thanks for the suggestion
well, at those voltages I suppose its probably a bit much. I was looking at the Sylvania data for the plate at 300v. It gives 80ma for the pair at that voltage in UL mode. Looks like Heathkit specifies 355 on the plates per the schematic.
