Heathkit TT-1 tester thoughts?
JohnMac
Addicted Member
I'm using a borrowed one of these and it's time to give it back or buy it. It seems to work fine. It's the only tester I've used so I have nothing to compare it to. Any thoughts how does this compares to other testers?
Thanks,
John
Mid-60s, not sure on price yet but have an idea what they sell for depending on condition. $100-$350.Manual, mutual conductance, emissions, leakage, life test. Not serviced or calibrated. I did clean it inside and out. Not the best cosmetic condition but not important if price is right.
Mostly wonder if this is a decent tester or if I should look for something else. I don't want to buy something then later be wanting something else.
I wondered about the readings. I tested the few new tubes that I have and thought they read a tad low. Then again, I have little experience at this.
Seems fine for determining if a tube is useable but accurate readings would be important if I were ever to sell tubes.
I trust the TT-1 does its measurements based on sound principles, but it has
to be calibrated if you are to rely on the measurement results and use them
on a commercial basis. I have had one for many years, but never got around
to restoring it or calibrating it properly. Being a well designed kit, it should
be possible to keep it alive for many years. The adapter (fitting in the cover)
is required for testing more modern tubes (compactrons, novars, etc.). If what
you have on hand does not have that adapter (sorry I forgot the model no.), you
might consider passing this unit (or buying it at reduced price as a spare) as
the adapter will be difficult to find separately. Good luck!
hey-Hey!!!,
That is the only tester that has a built-in oscillator for the gm test( instead of using 60 cps ). With the manual and a good set of tubes in it, calibrating it should be straightforward( and possible with simple tools ). I have a Hickok 752 and I'd love to find some way to justify a TT1.
cheers,
Douglas
I ended up getting the Heathkit for a very good price. After some research it seems that it will suit my needs. I was watching a nice TT-1 on ebay, was considering bidding until the bidding ran up and closed at $456. I got mine for considerably less so can afford to put some $ into it if necessary. It seems to work fine but wonder if I should do any work to it. I know someone that could calibrate it but should I first replace any components as a matter of routine?
I once found a web site that stated the most troublesome area was the constant
current heater supply, which basically uses the 120-V line in series with a large
capacitor as a current source. This is used on the 300-, 450- and 600-mA positions
of the heater selector. IIRC, the author said that at least one big capacitor in
this area was failure prone. OTOH, this part of the unit is not called up if you
select any other heater setting. I will try to look up that site. Good luck!
P.S.: this link should provide some great info.
http://www.kw.igs.net/~knickerson/heathkit.html
