Heathkit UA-1 amp rebuild
love pa amps
I had to completely disassemble and rebuild this amp for several reasons, 1) the wafer type tube sockets were installed from the top instead of the bottom, which looked awful and also placed the solder terminals on the sockets too close to the edge of the socket hole on the chassis where they had started to carbon track and short to ground 2) the front and sides of the chassis were in good shape but the top of the chassis and the transformers were badly discolored by rust, corrosion, peeling paint, etc, 3) the mounting socket for the filter cap was broken in several places, 4) the caps and resistors were all out of spec and the wiring was a sticky, moldy mess. After full disassembly I sanded, primed the top of the chassis and repainted it with RUSTOLEUM "metallic" gold which was a 95% match to the original Heathkit color. I used blue painters tape to mask the front, back and sides of the chassis which joined the new and old paint in a way that it appears to be a perfect match. After I removed their screws, the transformers were sanded, primed and repainted with gloss black Rustoleum. I installed 4 NOS brown mica top mount style tube sockets. Sprague 715P 600v .047 mfd coupling caps and 1%, 1/2 watt film resistors. I wired the amp with 20 gauge color-coded wire, RED-B+ /BLACK-B- / BLUE-audio / GREEN-filament, and WHITE for ac line. The filter cap was a MAGNAVOX multisection twist mount which reformed quickly and tested good on my Sprague tel-ohmike TO-5, it has been running cold for a week now with no problems. The only changes I made were:heath UA-1.jpg heath UA-1 top view.jpg heath UA-1 bottom view.jpg heath UA-1 bottom view.jpg heath UA-1 wiring detail.jpg upping the output cathode resistor to 200 ohms (recommended by Heathkit) and changing the main B+ resistor from 100 ohms 2 watt carbon to 600 ohms 5 watt wirewound to decrease the B+ voltage to match the voltages on the diagram.(same problem/cure I made on 2 other UA-1 amps I rebuilt) I re-assembled the amp using the original Heathkit assembly manual, following all steps as printed. The amp has been running for a week now with no problems and sounds great!!
I recently rebuilt a pair of EA-2/3 mono amps as UA type power amps since they were very ratty. I used 250 ohms in the cathode of the output tubes and run them with a bucking transformer which gives 115VAC line voltage. I also did some feedback tuning which improved the measured response quite a bit. I based my feedback circuit choices on Dave Gillespie's suggestions in his AA-30 thread. I also replaced the 100 ohm power supply resistor with a choke to reduce power supply ripple.
https://www.audiokarma.org/forums/i...e-rough-polishing-heaths-aa-30-aa-111.663199/
My thread:
https://audiokarma.org/forums/index...t-ea2-3-amps-with-stancor-51-30-opts.1010343/
Have fun,
John
My thread:
Have fun,
John
Hi, thanks for your post, the first real tube hifi amp I had was a Heathkit EA-2, long before I knew anything about the circuitry, I ran it for years "as found" it was a great amp, I later traded it to a friend, I now have several EA-2/EA-3 amps, two of which I re-capped and they sound great!!!, I will look into the feedback changes once I get my audio generator rebuilt, Thanks for the advice and the links, John.
