Thanks. Yeah, I had considered the tube being the culprit. But I have a few of them here and they are all the same from a noise standpoint. Having said that, it’s possible. Do you have a photo of your layout?
I had concerns about the orientation of the choke, but it’s mounted to aluminum and somewhat shielded?
How did you mount yours?
And it’s strange, as both amps make the same noise. So likely something I did on both. Question is, what mistakes did I make?
Used a ground lift plug, and didn’t make any difference. Having said that, if I remove the preamp RCA, it buzzes louder with the ground lift in place. Going to move the grounding point of the gain pot and see if that helps.
