It's a stereo amp and it appears the 807's are connected in UL.
I would check on that. The LS-35 and the LS-65 were UL transformers, but were not designed for 807's. Those were the only LS series UL transformers UTC made. It's possible the amp uses those, or employs a screen supply on the 807s to get more power, but if the amp uses LS-61s or 63s, there are no UL taps. Like I said, it's probably a very nice amp but I'd find out a bit more about which OPTs it uses and what the circuit is.
Now, the UTC "Linear Standard" circuit uses the LS-63 and a screen supply (on 5881s) for 20 wpc. The input and driver tubes are 12AX7 and 6AU6. That is a unique circuit with very, very low distortion. I have LS-63's and am trying to talk myself into building a pair of those. It's more complex than a Williamson so I'm hemming and hawing. ;-)
It would be interesting if you can get a pic of the amp or find out more about it. I use LS-57s with triode EL34's in an otherwise standard Williamson circuit for 16 wpc, and it is my favorite amp. The midrange in particular is just wonderful. So a UTC-based amp can offer a lot of pleasure if lower power is not an issue.
