Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Boyd 249G
bought it before Boyd bought Avid Thermalloy. Boyd has all kinds of stuff and an old brochure from Avid has thermal management products like these compounds as well as heat sinks and isolation materials.
Boyd 249G
Since the compound is only there to fill in the rough surface of the heat sink and the transistor, you use VERY Little on each device. A few grams will do a high powered receiver with 6-12 transistors fairly easily. You want metal to electrical insulator (mica) to metal connections not a blob of compound for the heat to have to travel through.
