illinoisteve
Running a cart-needle combination too lightly, allows the needle to bounce around in the groove--THAT will cause damage. What is important is proper set-up: best cartridge alignment, proper Vertical Tracking Angle, optimum Vertical Tracking Force for that needle. I personally wouldn't worry about record wear if those things have all been dialed in properly, even if the VTF needs to be up close to 3.5 or 4 grams, though I don't currently run anything that goes over 3.
If people get old records that have a lot of wear, it is a lot more likely that those records were torn up because some previous owners didn't replace needles when they were worn, than that they were damaged by the too-heavy VTF of cheap (possibly non-adjustable) record changers the previous owners used. They heard somewhere that diamonds were forever, and sapphires were for almost-forever. A needle worn to a chisel-like profile will tear up a groove, even if it is run at a light VTF.
