EWizard
Good afternoon gentlemen.
I have been plugging my Empire 208 table directly into a XSP-1 lately.
Between the pre-amp and an 8 channel amp I have a MiniDSP - 4x10HD which acts as an active crossover for some active speakers I [plan to] run.
Now to the issue. In storage I've had a Heed Questar MM phono pre-amp that I want to connect to my MiniDSP unit directly. Considering moving the XSP-1 stereo preamp out of this system and wanting to use just the MiniDSP unit as a pre-amp (both digital and analog inputs).
When the Heed is plugged into either the MiniDSP or the XSP-1 (regular non phono input) and the turntable is plugged into the Heed, I get a strange repeating popping sound.
When I unplug the turntable cables from the Heed it goes silent.
When I plug the turntable back in, popping continues.
Any idea what the deal might be?
The Heed unit worked fine the last time I used it. I've tried it near the turntable, and away from it.
It is away from the speakers by a couple of feet.
Not sure what else to try at this point. I'd like to use the Heed (without the XSP-1) to see if I can deal with not having a more robust pre-amp.
Thanks!
Thanks!
