the skipper
Professional Curmudgeon
My take was "Is a one decibel difference audible?"
Mine too.My take was "Is a one decibel difference audible?"
Good point, we need to define the reference. Ive been discussing dB SPL, as that is what the app-based sound meter measures.Was the OP misunderstood? I dont think he was asking about 1dB absolute value, but rather difference. Its logarithmic. xdB to x+1dB is not the same as say xmV to x+1mv. when graphed.
YES! My error. Corrected above.Halving distance gains *6dB* of SPL.
These are all theoretical numbers based on ideal models. Everyone is different, but they reliably describe the performance of sound in an environment.How is “ perceived loudness” determined?
But can we trust this?
67.4% of all statistics are made up.![]()
It's the Internet. Everything is true.And the other 33% are misinterpreted!
Everything is a lie unless it comes fact checked from the Ministry of TruthIt's the Internet. Everything is true.
Congratulations on your excellent hearing and not having theoretical ears.
You guys need to get real. A change of just 0.2 dB is audible in a quiet controlled environment, especially if it is in the critical midrange area. But you need to be able to instantly A/B the change.
My Yamaha RX-Z9 voluime control is calibrated in 0.5 dB increments, and I have confirmed this many times using a PROFESSIONAL sound level meter. I can typically hear this 0.5 dB change as I adjust the volume across the volume range, and can always hear it when it is in the critical listening range.
Yes, because it has to reference something to have meaning.There's no such thing as a "1 dB absolute value".
A 1 dB difference tolerance between channels is very common with phono cartridges and actually, probably in other components,too. If that's all there is, I would stop worrying about it and balance the channels with the balance control. What dcmfan said is true, too. Speaker placement and room effects can influence perception. With my quad system, I have to have the balance controls favored to the left a bit because the two right channel speaker stacks are against a wall and the left channel stacks are not.
Doug
Thanks all.
My studio room is not Symmetrical, not sure if it is the reason.
I moved the speakers and subwoofers here and there, now both speakers seem balanced in the listening position.
Another, I connect subwoofer to only ONE (right or left) preout of the receiver, I found it effects the speaker volume level, means the speaker on the being used preout side is weak a bit.
Thanks.
