(Help) 1st time Changing a woofer
Kaysen95
Hey guys :) !
First post here! Please pardon my english, not my mothertongue ; I wont know the technical terms you're gonna use ;-D !
I'm trying to change a couple of speakers for the first time by myself, and I'm not pretty sure of what I'm doing ! I'll require a lil' help here please :)
So basically, I've been given those two speakers by my brother ; the two woofer at the bottom are dead, and I must change em ; Here are the poor infos I've got :
So I'm trying to target what to buy, to be sure it's gonna work -
The woofer size are 8 inchs
I found those online, could you guys tell me if they are what I'm looking for ? And Is it gonna work correctly ?
https://www.kijiji.ca/v-view-details.html?adId=1457703665
thank you very much for your help ! :)
Today's noobie - Anto
You need to find out what impedance the original woofers are.
Given that the cabinet is rated at 8 ohms- chances are the woofers are either 16 ohm (wired in parallel- more likely) or 4 ohms (wired in series- less likely).
Hopefully, they will be marked on the rear of the woofer. It would be worth pulling one out to see, before trying to buy replacements...
Regards,
Gordon.
THank you Gordon for such a quick answer !
I dismounted both woofers, and this is what I've got ; no more ; is this what we're lkg for ? :s
Do you know anyone with a volt/ohm meter? It would be best to test one of the still-working woofers, for resistance.
If you can arrange that- you would be looking for a resistance reading (on an ohm meter) of about 10 to 15 ohms for a nominal 16 ohm woofer, or 2.5 to 4 ohms for a nominal 4 ohm woofer. That will tell you what you'd need to buy, to replace the dead ones.
If you can find a suitable replacement- I would recommend putting one of the working original woofers in the top position in each cabinet- and one of the new woofers in the bottom position in each cabinet. That way, they two speakers should sound the same as each other.
Regards,
Gordon.
No, I dont ; Maybe an electronic shop that I know
Okay, I got what you say, thank you for your advices !
I'll keep the topic open for the following step if I've got any further questions.
Thank you Gordon !
