I have 2 marantz 2235b systems that both do the same.
The issue: the right channel on the main, backup/remote and headphones stops working after about 10 minutes (sometimes longer). If I turn the volume very high, the right speaker crackles and then starts working again.
I have noticed occasionally that the sound in the right speaker fades out slowly.
I should note, the right speaker isn't completely void of sound. It is just very low, nearly silent.
With that stuff being said: the relay on the power board works properly..it looks like if it was the relay, both speakers would die.
From my experience with electronic devices, it seems like possibly a capacitor failing open or resistor that heats up causing resistance to increase. That leaves a lot of options..Could be wrong, I have a cheap multimeter but no scope for testing.
I'm typically alright when it comes to fixing circuit boards and broken electronics. But this system is large and has wires everywhere.. I don't want to take it completely apart and find out the issue was something easily accessible.
Any help would be appreciated. Thanks!
