And make sure the exposed metal face/side of transistor is oriented face down towards the heat sink/mica insulator.I see you are using Hitachi transistors like I did. Just mount and connect them like the originals. After you mount them onto the heat sink measure with an ohm meter across the center lead (collector) of each transistor and the heat sink. If you have any reading other than an open circuit then recheck the insulating kit (mica washer and plastic screw sleeve) for that transistor. Proceed with soldering short lead wires from pcb to each transistor lead watching carefully for correct configuration (consult the schematic for that).
I wonder?Get this thing working get?
My bad Bk has to take a break on this fix before I start smashing this scope. Why won’t it work like it should urghhh need my cotton candy..Get=yet, bloody iphone
Yes, it is the correct pinout. I see what appears to be mica washers between the heatsink and transistor, did you use the plastic screw sleeves? Were the mica washers intact when you installed them?Is this the correct pinout on the board?
Have you done what ausman1000 suggested above?After you mount them onto the heat sink measure with an ohm meter across the center lead (collector) of each transistor and the heat sink. If you have any reading other than an open circuit then recheck the insulating kit (mica washer and plastic screw sleeve) for that transistor.
Plastic screws? No I didn’t use plastic screws just these metal onesYes, it is the correct pinout. I see what appears to be mica washers between the heatsink and transistor, did you use the plastic screw sleeves? Were the mica washers intact when you installed them?
No, plastic screw sleeves. They are installed in the transistor screw holes before you install the screws. It, like the mica washer, is used to prevent the screw from grounding the transistor to the heatsink.Plastic screws?
It's been awhile since I looked at the schematic but I don't recall any of the flying wires crossing each other in the view shown. It kinda surprised me because flying wires wouldn't be necessary. I'll have to look again...Also, you have to use flying wire leads to connect transistor leads to the pcb. You cannot just solder transistor directly to the pcb because the hole arrangement on the pcb is not ECB or BCE. Two of the leads are swapped and I can't remember which ones that is why you will have to consult the schematic
I have a late and early version of the 18 so I will look at both. There may be a difference in the transistors used and thus a difference in lead configuration.It's been awhile since I looked at the schematic but I don't recall any of the flying wires crossing each other in the view shown. It kinda surprised me because flying wires wouldn't be necessary. I'll have to look again...
