Carl in FL
Folks,
I purchased a 1600x USB microscope to check my stylus on my V15 VMR stylus; I'm the original owner (!) and I know I've not played more than 100 records on this stylus. I've added photos to this post to see if anyone sees what I do; a misshapen stylus as if one side is more worn than the other. It's mounted on a SME Type III arm on a Thorens TD126 MK III turntable. Is it enough to be concerned, or is it within tolerance and usable?
The last image is view from top to check wear:
I know factors like azimuth, anti-skate and table leveling are factors if this wasn't the result of a poorly cut diamond. Has anyone else seen one shaped like this?
