Stanton681EEES
Addicted Member
PLEASE READ THIS CAREFULLY
Thanks.
I've been using the 1600MKII but some of the automation isn't working and I can't figure out what the problem is, the cuing works fine but for some reason when I push the start button the arm doesn't moves over the record and lower, I have to move it by hand then when I hit the start while it's over the beginning of the record, it will lower then it runs for about 2 seconds then the arm lifts, and returns to the arm rest, plus the arm doesn't raise at end of the record, unless I hit the Start/Stop button.
I removed the gray cap at the arm base and adjusted the screw under the arm base and it didn't change a thing.
Now when I cue it manually it works fine but at end of record I have to hit the start/stop button and it cues and returns to the arm rest.
I thought that when I first tried it the arm did raise automatically at end of record but I can't be certain that it did, because when I first got it it didn't power on and I had to get new fuses for it that I put in to see if this thing would power up, so I could inform PayPal as to my claim against the seller.
I then striped it down to cleaned it and put it back together.
Hopefully when I cleaned the gears under the arm I didn't mess something up. I had to remove the sensor that attaches to the motor board as I dropped a screw down under it and the only way I could get it was to remove it.
Everything else functions fine or at the present moment it does.
So what should I check? Or could be wrong?
Thanks.
Thanks.
Thanks.
