i am attempting to work on this adcom gfa 5500 i have.
cracked it open. a little dusty but looks good.
no bad looking caps. no heat marks. resistors look good. nothing looks modded.
these are the instructions for setting bias and dc offset.
BIAS ALIGNMENT
Prior to performing BIAS ALIGNMENT turn unit on and allow to idle for approximately 5 MINUTES before
attempting adjustments.
1. Connect millivoltmeter across emitter resistor R52 for left channel (R51 for right channel)
2. Adjust bias pot P2 until meter reads 50mV +/- 5mV
DC OFFSET ADJUSTMENT
1. Connect millivoltmeter across speaker output
2. Adjust DC offset pot P1 until meter reads 0mV +/- 10mV
do i simply attach my mm to each side?
do i connect to it before turning amp on?
and for dc offset, i go across this post?
do i turn amp off then back on and wait for it to settle for each measurement?
been a looong time.
thanks for your help.
BIAS ALIGNMENT
been a looong time.
