Vintage fully functional Dual 1209 turntable. Dual set the standard in the 1970s for high quality turntables. This unit features 33/45/78 speed settings with +/-6% adjustable pitch control (semitone). It has an adjustable counter-weighted tone-arm, anti-skating adjustment, cue control, multiple platter spindle, solid wood plinth, and stylus force adjustment. It has a spring-suspension chassis to dampen vibration and a solid metal platter. The motor features direct-drive gears (will not slip or lose speed like modern belt driven turntables). Currently this unit contains functioning "Shure Hi-Track" needle cartridge. Has original intact plastic dust cover and original print owner's manual. Includes grounding wire and RCA style inputs for connection to your head-unit or amplifier.
I've read about dual's is this a good unit? Thanks for the help?
