webbrewer
For my small home recording studio. I have a rather strange set up where I'm using an old Technics SU-V707 to route instruments to a USB audio interface via the external in/out jacks. The interface sends the signal to a DAW on my pc, and then returns the audio back to the amp/speakers. This allows me to leave everything plugged in and just change the input via the amp's input switch.
This worked great for a while but I ran out of inputs so used an old Fender pa mixer to add a few more inputs for mics and such. That also worked fine, but after removing the Fender pa for an event and reconnecting everything, I noticed one stereo channel wasn't working for instruments plugged into the mixer. A little later neither channel was working. I assumed it was the mixer - if I plug the mixer into another input it doesn't work.,But when I eliminated that possibility by trying other inputs not using the mixer on the amp, they didn't work either. Since the amp still plays audio back from the pc via the interface > external input, it seems to be that the external output isn't sending anything to the interface.
My next step is to try another amp but before I risk frying that too, would like to know if anyone has any experience / insight into what might be happening. I realize the Technics may just be showing its age, but I've had it from new and it wasn't in use for 30 years so doesn't have a lot of miles on it.
