redpackman
i have come across two vintage Stanton cartridges. One is clearly an 881S. The other says Stanton on the top but does not have any other identifyng marking except for the numbers etched on the side.
Both styli seem to be in good condition.
First what do the numbers etched on the side indicate? They appear to be individual readings of some sort that were factory applied.
Perhaps help in IDing the cartridges: The 881s has continuity in both channels around .760k. The cartridge with the D81 stylus has continuity in both channels around 1.25k
What do I have here?
Thanks in advance.
Thanks in advance.
Thank you so much for all the information so quickly. One question. It was affirmed that the styli ought to be switched between these two cartridges because the 881s is a Stereohedron stylus, and yet the brochure posted just above this post advertises the 881 as having a Stereohedron stylus.
