ecluser
Your measurements seem to confirm what I suspected from the beginning.
Cap C4 seems open. You should replace this cap. The exact value is not important, at least 2200 uF, and at least 35V according to the schematic, but 50V in my opinion.
At LP54, you should expect to see a few Volts for the ripple, say 1 to 3 VAC, but not 50VAC
With a new cap, the DC voltage at this point will be much higher. I suspect it will be close to 30 or 35V.
If the minimum voltage at this point is higher than 27 or 28V, regulator Q2 will operate properly (but to the limit). From your measurements, the minimum voltage at LP54 is... OV (the DC Voltage minus half the AC Voltage)
Does it make sense to you?
