Help ID this speaker
P. S.
Hi,
I can get the speakers from the picture for $100 locally. The owner says he cannot ID them. He says they have black grilles. From the photo I see the woofer might be Alnico but not sure.
The horn - I have no idea what it is ;-)
Looking for help ID-ing these and "dollars & sense" advice.
Thanks,
Tweeter does look to be EV, but i'm going to go with a CTS or equivalent woofer as was so popular with mid-cost setups. Only way for me to know for sure is to see the back, others may be better at IDing the woofer.
Thank you for your help!
Judging on eBay prices - the horns and woofers themselves (if they are indeed d130) are worth a few $100s. Good news!
Update on my story with these speakers.
The seller recently dropped the price to $50 so I decided to pull the trigger on these. What I got is apparently a custom built "spinoff" JBL c36 speaker.
The cabinet is built very well out of thick, stained + clear coated plywood following original c36 dimensions. There are legs on the bottom allowing for vertical speaker tilt.
I pulled the back of the cabinet and found:
* JBL D130 woofers
* EV TW35 horns
* EV Wolverine CR35 crossovers
Overall - I am happy with the purchase. Hooked them up and they sound good with my test amp. Very forward sounding mids, good level of detail overall. After I clean up the crossover pots - I will give them a try with my Sony STR7065 and Scott 388B which I believe will be best match.
-Peter
I dug a bit into the c36 clones research. Apparently this was a thing many people did back in the day . The EV wolverine CR35 crossover + TW35 horn were apparently sold as a kit to build ones own speakers. Interesting read overall - most info can be found on lansingheritage page.
-Peter
@BillDurhamB That's what I did! They are already in my garage awaiting crossover pot cleaning. ;-)
Sound very good with my test amp (Nikko sta-5010) but I am expecting more when paired with one of my more vintage receiver - Sony STR7065 or especially Scott 388B.
Wondering if I should attempt to build a clone of JBL N2400 crossover for these instead of regular wolverine.
-Peter
