help identify compression driver
mgman
Hi, I have a set of compression drivers from horns i got from my neigbour. One burned out so i replaced them with peavy 22xt. There is nothing on the driver to identify it, the horn is an 'HH Electronic' model. I'm trying to find replacement diaphragms. 2" vc.
i found replacement diaphrams in canada at Yorkville Sound for $40 CDN. Where did you find the specs for the driver?
thanks
thanks
Great deal if they're genuine phragms, those specs were from a site in the UK (TW101), I also saw these posted from a 1986 catalog in the DIYaudio forum;
HORN DRIVER
PE : 50WATT
IMPEDANCE:8 OHM
FREQUENCY RANGE:450-16000 hZ
SENSIB.:103 dB
CERAMIC MAGNET
FLUX DENSITY:1.74 TESLA
MINIMUM CROSSOVER FREQ.: >800 Hz
