Help Identify This Audio Technica Cartridge
iramegdal
Well-Known Member
Can anyone help identify this Audio Technica cartridge? Just purchased a Yamaha YP-211 turntable with it. Need new stylus, it appears. Can anyone help identify stylus? Cartridge looks tarnished, but I assume that it is good. Table is in excellent condition.
If you remove the cartridge from the headshell, the label with the model number will probably be on the top of the cartridge.
I'm with lini on this one. Looks just like my AT13Ea. Lini, won't the ATN14 stylus also fit?
wualta: Yup, the ATN14 would also fit, as would the ATN13EaV and ATN13EaX as well as the ATN14E and ATN14Ea and also the LSN500 and DRN500. But the depicted one is an ATN13.
Greetings from Munich!
Manfred / lini
mythless: Nope, the AT12XE just had basically the same generator, but with a differently shaped plastic frame around - and hence also a slightly differently shaped needle. In addition, the ATN12XE sported a lower ranking configuration with straight instead of tapered alu cantilever and a medium-sharp elliptical nudie with round shank instead of a sharp, true elliptical nudie with rectangular shank (just like the ATN120E/122EP compared to the ATN130E/132EP).
Manfred / lini
