Tucson Mon
This is my first turntable, so I have zero experience in the area.
Thanks for your help!
The correct original Pickering stylus will have the D2000 or D2400 on the top under the brush crossbar.
Model ID will be in the same spot-Pick did ID some models with a dot or ellipse but those would not be for their UV-15 quad cartridges. Genuine Pickering styli will also have a tiny Pc embossed on the right side of the front facing.
I don't know the history of this turntable, but the cartridge is definitely a UV15, I can see it printed on the side. Unfortunately I don't have any quad vinyl to test it on to even see if it's a quad stylus to begin with.
Given the information, how should I go about identifying this?
Is that a round dot printed on top of it? That would indicate a conical stylus.I took a picture of it lifted.
Any other ideas?
TVOM still has a list of the original styli for reference (long sold out) https://www.thevoiceofmusic.com/cat...=MfgNameNeedles&MfgName=Pickering&Categories=
Keep in mind you might have an original Pickering brush installed on an aftermarket stylus.
