Help identifying these Altec horns please.
Borg7x9
Member
Hi guys, Hope you are all holding up well on the other side of the Pacific !!
I recently spotted these on a local website and Im hoping someone will be able to tell me if these are 805 horns or 803 horns. Im hoping 805s and ill be able to put my 288-16ks on them and crossover at 500hz. They appear to have the correct throat adapters for the 288s as they have 290s on them right now. Im also thinking that they might be a pair of tar filled horns which would be nice. Let me know what you think…. comments gratefully received. Thanks all.
They appear to be Altec 805s, which are about 17" wide and cross at 500; 803s are larger, about 26" wide and can cross at 300. They're tar filled, very cool. They're very heavy.
Thanks Tom, I’d almost given up finding a local pair, and then these pop up. Hopefully I can drive and pick them up when the auction ends. I wouldn’t want to have to pay to ship them any where, that’s for sure.
They look tar filled to me, 805's would be about 13 x 24-1/2 inches excluding any brackets, 803 is 50% bigger
Thanks BT. Part of me would like them to be 803s as I think it would be slightly cooler to have the bigger horns, but then at 50% bigger they must weigh about 40kg without drivers !! Probably be easier to wrangle a pair of 805s. Either way they are cool so I’ll try and get em. I'd almost given up finding a pair locally in NZ and these pop up !! My crossover and 288s are 500 hz , so i can’t go any lower with the horn anyway. Thanks again for your reply.
Tom, I just had a thought….are you Tom from Chicago horn loudspeaker guys ?? If so i just wanted to say i really enjoy what you guys do. So thanks for taking the time to create all those videos… Ive watched most if not all of them. Those recent electrostatic towers looked Amazing. Keep it up please, you guys are very much appreciated. Even in NewZealand. .
They are too short to be 803's.. They are Tar-filled 805's with 290-16k drivers with phenolic diaphragms. They were used in public address systems.. The Altec 290-8/16K drivers are the only drivers that I know of of that era that go down to 300 Hz. They can be mated with a 803 to play them down to 300 Hz. But the horn they are mated to are definitely 805's FWIW that particular setup would not be great sounding in a HiFi setup IMHO. Say 300Hz to 7000Hz. They were probably from a stadium of some sort for PA system $1000 is a steal just for the horns ... Good Luck !
They are too short to be 803's.. They are Tar-filled 805's with 290-16k drivers with phenolic diaphragms. They were used in public address systems.. The Altec 290-8/16K drivers are the only drivers that I know of of that era that go down to 300 Hz. They can be mated with a 803 to play them down to 300 Hz. But the horn they are mated to are definitely 805's. Is that just a single or do you have a pair ? FWIW that particular setup would not be great sounding in a HiFi setup IMHO. Say 300Hz to 7000Hz. They were probably from a stadium of some sort for PA system
Thanks AB. I agree. They are a pair of horns and drivers...and Just down the road from me. I managed to find a pair of 288-16k with original Altec Diaphragms a few months back. So I'd be swapping those in. Hopefully that will give me better Hifi performance.
