electrofelt
Hi everyone!
I stumbled across here searching for info on a Kenwood PC-400U. I'm a novice in this world but I'm hoping for some suggestions on repairing/caring for my record player. A few years ago the needle was damaged resulting in scratchy sounds, since then it's been wrapped up in the attic.
I took it out to sell it, but instead I think it's worth resurrecting. I've read a few comments that say it's a good table but it's been neglected. Any suggestions on general beginner how-to's would be appreciated, the manual doesn't seem to be available for this guy...
It looks like it has a Grado G cartridge, but I can't see any other identifying numbers. It's a medium tan, not green like the dining room lights suggest. Do you think it's possible to find a replacement needle or should I just go with a newer set-up? Any suggestions on types that would fit? Or maybe another reason I might be getting the scratchy sounds...
The insides probably need some cleaning/greasing too. Molybdenum grease seems generally suggested but what type of oil should I use?
And I apologize for the ignorance! Thanks in advance if you take the time to reply.
Jess
Click the pic for high-res.
Jess
IMG_0310
IMG_0325_2
SF103787
SF033695
