Help!! MC-2255 Right Channel Issues(Broke)
WhoDeanE
I turned on my Stereo (MC-2255, C-33, MR-75, XR-19's) and and sound came out of the right channel for a split second and Never Again... Help me diagnose it please!!
here is what I have tried so far...
1. reversed the RCA to check the cables.. Cables good
2. tested headphones - Right did not work
3. put another speaker on the channel - did not work
I inherited this setup from my Grandfather and have the same Passion for music as he had but not the same Wallet if you follow. I want to Fix this but am at the same time affraid to find out the problem$$.
Thanks
Mason
You have a great setup... I hope you keep it and the issue is minor.
I am sure more technically experienced members will come to help , in a meantime:
Are you sure it's the amp? It could be a preamp as well.
You said you reversed cables to check them ; you should also connect Left preamp OUT to Right amp IN and opposite. This way you'll now if Right channel is off, it's the amp.
Have you checked the mono/stereo switch at the back? My 2205 has it, not sure about 2255.
Good luck
Nice gift from your grandfather......
I think you are saying the RH headphone jack on the power amp was missing sound......swap the input from the preamp L for R. RH still out?
If that is the case it is time to treat the amp with the respect your grandfather would expect and bring it to a local tech. Maybe the switches on the back are dirty.....well there are lots of maybes.
There is no repair inside for someone to learn to be a tech.
Hello
Does the auto-test stop on one particulary step when you switch the power on ?
What is the serial number of the unit ? Between CT1001 and CT3264 ?
Tested go through all the steps and the tach still reads and moves. I also plugged a source directly to the amp and still nothing.
I have a MC2500 on the bench right now, that I was concerned with developing a problem similar to yours. Because of some cheating typical flipper crap, this possible potential problem was purposely hidden from the new owner.
A bench test confirmed the issue is a display issue and now we can proceed with a repair that while not inexpensive, is a lot cheaper than it could have been.
So, time to get your amp to a local tech. As in all trades labor rates vary greatly depending on were you live. $75.00 to 100.00 US for parts and 4-5 hours at your local professional trade labor rates would be my estimate. I would suggest recapping the small signal power supply while the amp was open as well as the driver boards.
Thanks for everyones help
can you
Thanks for your help
can you explain a little what a display issue is?
Good luck
thank you
i thought it could be the preamp too so i plugged into the amp directly and still no sound from the right channel. yes i checked the rca by switching it no luck
[QUOTE="WhoDeanE, post: 9401958, member: 2216
can you explain a little what a display issue is?[/QUOTE]
If your PowerGuard display goes into full locked on red.....well since PG monitors distortion it usually indicates a major amp issue.......in this case the previous "owner" unplugged the display not bothering to fix the problem.
Luckily upon bench testing it turns out to be a broken PG display driver not a amp section problem.
