All these DAC terms are making my head spin, OP amps, R2R, tube or no tube, etc etc.
Let me back up a bit here and explain how I ended up even considering a new DAC.
Again, source is 99% 44.1/16 FLAC files streamed from my NAS, no plans to ever use DSD or MQA whatever those formats are.
3 months ago my setup looked like this:
NAS/LMS -> pCP -> hifiberry DAC+ pro -> Sansui AU-9500 (unrestored but adjusted) -> ADS L1290s (restored mids/tweeters by Richard So)
That setup sounded really great *with the loudness switch on* and listening to my go to ref music (Steely Dan/Pink Floyd/Stevie Wonder/Ohio Players)
The problem with that setup is when I played modern stuff I like (Daft Punk, Rage, Tool, Foo Fighters, Alabama Shakes) it became congested, too forward and well... distorted (I do occasionally play it loud, maybe 11 o'clock, sometimes noon on the dial). I understand maybe some of the above possibly could be chalked up to the loudness wars, but not Tool or RATM, they are know for good masterings of their recordings)
Recently I was able to pick up a Mcintosh MA-6450 integrated. With the rest of the chain same as above it sounded better, no, much better. But, still missing something.
The thought occurred to me that I had a $40 DAC going into pretty expensive amp and that the DAC might be the problem.
So, I changed my hifiberry DAC out for a hifiberry DIGI+ (using the coax out) to a new Topping D30. It did sound better, I A/B'ed them and the D30 had a slightly wider soundstage and less rolled off highs. Still not perfect with all the different music I like but getting closer. The Topping D30 had to go though, serious problems with it, power connector was flaky and loud pops/scratching when changing sampling rates. The D30 is on it's way back to amazon.
I now have an Emotiva XDA-2 on indefinite loan and A/B'ed that against the Topping D30 Again, slightly wider soundstage on the Emotiva as well as a more accurate but slightly laid-back sound. While using it though, I still reach for the variable loudness on the MA6450 and crank it a little to get a little more punch.
Got some really great advice from
@E-Stat on the transport side of things. Did some tweaks on the PI and I've ordered the Allo digione and a battery power pack to ensure I'm doing the best I can with the transport.
After starting this thread and all the reading and videos as well as personal experience, it's become very apparent I can't cheap out on a DAC. Also, while the question of "filters" can be a subjective one, I like the idea of having them available if want to use them. Kinda like someday I'm going to start listening to Miles Davis, not today but someday.
Don't want to get this thread moved so I wont mention exact prices but here's my list right now:
Under 2k:
Chord Qutest
Under (barley) 1.5k:
Benchmark DAC2
Under 1.3k:
Schiit Gungnir Multibit
Under 0.8k (used):
Rega DAC-R
Bryston BDA-1
Of all the above, the only ones I could audition are the Schiit and the Rega. The Rega is local and I can bring the XDA-2 to compare. The Schiit would be a 15-day trial, but with my amp and speakers.
The things John H. Darko said about the Chord Qutest really makes me wish I could still deduct my home mortgage interest.
Then there is also the thing that
@Decibel_116 said: "The only one that sounds better than the XDA-2 is the Chord Qutest" once I read that, I can't seem to get it out of my head.
Anyway, I really appreciate all the helpful suggestions and insights.
