Help me choosing a pre phono and TT matching
nicolonez
Hi to all!
I'm here to ask your opinion regarding a new phono pre-amp for my main system.
Actually, I have a Dual 1019 TT with AT95E connected to a tube Fisher KX-100 amp, and I'd like to make a step-up. In particular, I have these cartridges to choose from:
- Pickering XSV3000 (with LP Gear Vivid Line aftermarket stylus);
- MoFi Studiotracker MM cartridge;
- EMPIRE 4000 DI with original stylus;
- Denon DL-103 MC.
I'm looking for a good phono pre-amp (max. 400€) and after trying the ifi Zen Phono that I didn't like, I'm stuck between these two:
1. MoFi Studiophono;
2. Pro Ject Tube box S2
The speakers are JBL 4311 (full alnico version). I like 60-70's rock, blues, jazz and indie music.
What's your opinion of these two pre-amps? And what could be a nice match between the TT/cartridge/pre-phono?
Thanks
Nicola
Will I have “problems” with one or more of the cartridges to match the tonearm mass (11-12g I think)?
I think 11-12g would be called medium mass, so that should be good to go with a whole mess of Cartridges out there.
I gather what you need is a Moving Magnet Phono Stage, correct? There's tons out there, and good doesn't have to cost you a Kidney.
I’m looking for a MM/MC phono pre-amp because I have also the Denon DL-103 and the tube Fisher doesn’t have an MC phono stage.
I’m asking what you think is the best matching with cartridges I have and the Dual 1019, and also between the Pro-Ject Tube Box s2 and the MoFi StudioPhono should be the “right” choice.
How about a decent step up transformer? You may need to spend a little more to get something nice, though. You should be able to find a Denon SUT within your budget. Otherwise, you will likely want a 20:1 SUT to get you in the 6mv range (on the DL-103.)
I'd go for the Pro-Ject Tube box and a pair of good 12AX7 tubes.
And what about the compatibility with the Fisher KX-100 Tube amp that I'm running? I love its warm warm sound; maybe adding a tube pre-amp is not necessary? This is my doubt regarding the Pro-Ject tube phono.
The Denon DL-103R is going to need a stand alone phono pre-amp with enough gain. Or a step-up transformer.
With a phono pre-amp you'll will need to plug it into an unused AUX or TAPE input. So, the signal will see most of the Fisher's tubes (only bypassing the built-in phono stage). :)
Hi to all!
Nicola
Strange you didn't like the Zen Phono, which is perfect for the Denon 103. Too much bright for you maybe?
the problem was that I didn’t feel/hear any difference between the ifi and the Fisher phono stage… but I didn’t try it with the Denon 103.
Well...if that is the problem I would think the phono stage in the Fisher is very good. :)
But you probably disagree, isn't it? What do you expect from a new phono stage?
The AT95 is a relatively bright cartridge so if you are wanting less 'bright' and more 'full' I'd change the cart first.
The Zen iFi is definitely a decent pre so if you didn't hear much of a difference, I'd say either the Fisher has a really good pre or your system isn't resolving enough to show the difference.
Are those carts you listed local to you or do you have a buddy that has them? I have an Empire 3000 with an upgraded stylus that I feel is very good. Very lively. I'd call it balanced, not really 'full' in my opinion.
The 103 is a great cart in many ways but as mentioned, you'll need an MC-capable pre or a step up transformer so unless you're getting a scorching deal on the cart, this will be a fairly costly option to try and the stylus isn't easily/user replaceable on the 103.
While some people don’t like the idea of a phono pre that’s made in China, the EAR “clone” I have, sounds superb. Read up on these EAR copies; they’re very popular with folks on Lencoheaven forums..
The above will work very nicely with all of your MM and MI cartridges, and if you add a SUT, with your MC as well.
