So I have the chance to get both but can only buy one... Actually I shouldn't buy any but you know the rest....
Anyway, specwise I prefer the A3. Yes, yes I already know the A100 has a special topology.. But the A3 is better spec wise in everything except distortion, which is not that different in practice with the A3's being also ridiculously small. And build quality wise probably one thing that a lot of you in the US don't know is that the transformers for Europe were more powerfull. The European version of the A3 has a total of 2300Watts in power transformers, at least that's what's marked on the back of the case and in the service and user manuals. The A100 has only 1350w. The capacitors are about the same, 80.000uf per channel so overall the A3 is better equiped. Also the heatsinks are bigger in the A3. Power output is also bigger on the A3, 200w@8ohm/320w@4ohm vs 170w@8ohm/240@4ohm...
I don't know....:sigh:
I've heard plenty amps with decent speakers and they didn't sound that different, provided they were solid state and powerfull enough, the room and speakers were what made the biggest difference. The New Class A synchro bias is also not bad.
The only thing I don't like about the A3 are the original transistors, which this one still has (which on the other hand might be a rarity by itself ...
) but those can be changed later on, even if it's a PITA, I think there are replacements that preserve the original specs of the amp right ? I have read about people upgrading/replacing them and not mentioning any difference but I'd like to be sure the function/sound of the original design is preserved.
Help!
Help!
