gentilhommes et madames-- for your curiosity and viewing pleasure, shrinkboy, with the kind, able, and highly informed assistance of paul c, has completed the 'project' on view here: a set of hgih quality, home brew book shelf speakers.
to review, it began as a set of raw, semi finished cabs made of 1" MDF, ported, and cut for 4" woofers. i picked them up from an audio meeting at russman's ....
the original post was for some help on deciding on drivers and x-overs. member extraordinaire, paul c, leapt to the fore, with not only detailed recommendations, but also schematics, graphs, charts, parts lists, etc and an offer to construct the x-overs if i sent him the parts, which i did.
he turned the crossovers around almost immediately, which i photographed and stored in a laptop that i subsequently DROPPED !! (SOB).
as you can see, i finished the cabs with two coats of kilz, sanding in between, then sprayed with coats of krylon gloss black. having ordered the wrong input connectors, i had to reorder to get connectors with a threaded post long enough to get inside the thick walls of the cabs.
too eager to wait for these, i mounted up x-overs and drivers. (4" Tang Band from PartsExpress, and Peerless Silk Dome Tweets from the auction site for $17). from the data paul had on the woofs, and from what i sent him on the tweets, he constructed a superb x-over which i glued into the upper left hand corner of each cab. paul carefully labeled each wire so as to make sure that Mr. DIY-not got everything in correctly. i must express my thanks to paul for his guidance and encouragement. i mean really. above and beyond the call and in the spirit of AK if ever there was such thing.
set 'em up on the HT rig, which includes an Echowars rehabbed and modded Pioneer SX-780 (clean highs, PUNCHY bass) and a JBL subwoofer.
so far, i have listened to some downbeat electronica (lots of bass, high hat, tinkling, floating keyboards) and The Shield DVD (voices, gunfire, explosions, music) and they are superb. magic, solid soundstage, voices coming from points in space. the Peerless tweets really do high hats and cymbals well. still gotta do some strings, female vocalists, etc.
but i am super happy with the results. see for your selves...
