lossfound
OK, need another speaker ID (sorry). These little guys just turned up and I've refoamed them.... they sound great!
The speakers bear "Image" brand logos on both grilles, and are marked as fabrique au Canada (thusly I assume the brand would be pronounced "im-AJ")... no other indication as to model, serial, or impedance on the back. I am pretty sure this brand had something to do with Mirage at some point for the following reasons:
Dimensions are pretty much exactly 18x9x9". Driver complement is 6.5 and a small dome tweeter. The woofer looks an awful lot like the one in my early-90s Mirage m290s, but it is a very slightly different impregnated-poly-ish material in the cone, and has the aforementioned foam surround instead of inverted rubber like my Mirages. The tweeter is a distinctly different design from my m290s, looks like a Vifa but I haven't pulled it to check.
Meanwhile, the cabinets bear a very close resemblance to *earlier* '80s Mirages I've seen in person / on eBay... but the drivers look absolutely nothing like the ones in those. They're a step up if anything.
Google / eBay / AK search is not terrifically helpful so far, not least of all due to the sheer futility of a query like "image bookshelf speaker".
Anyone have a clue what these are?
