Hi
I am trying to learn how to draw the load line. I am thinking about using KT88 as it's the only one that gives the graph of UL. The article I use to write this started out with RDH4 P584 in the part of drawing the composite load line of pentode. More importantly, using the Valve Wizard article: http://www.valvewizard.co.uk/pp.html in drawing the composite and class B load line.
I am using Ebb=420V supply. The steps I did:
1) Draw the composite load line of my choice with one end at ( Ebb=420V, Ib=0mA) and draw the load line below the max power dissipation curve. The Composite load Rc = 420V/0.36A=1.166K. Therefore Raa = 4 X Rc = 4.67K. The Rc is drawn in RED color.
3) I then draw the class B load impedance of 1/2 X Raa = 2.33K. I adjust the line up and down to find the idle current where the class B load line still below the max power dissipation curve and draw the line in BLUE. The idle current is 70mA as shown:
3) I calculate the output power P= 1/2 X (420V-30V) X 180mA = 35W. More realistically, P= 1/2 X (420-50)V X 0.18A = 33W as I don't expect the plate voltage to go below 50V
Lundahl 1679 primary impedance is 4.5K, it's very close to what I have here.
Can anyone verify whether I am correct in this graph and calculation?
Thanks
Thanks
