ViperZ
Well-Known Member
Hi all,
I have this integrated amp. The amplifier circuitry is fully working - I can trace sound all the way to the relay contacts, DC offset is a couple of mV on each channel. The relay works too - I can trigger it externally.
The whole protection circuit is turned off - D903 is not biasing at all, no current going through relay coil, so I get 0V across coil - 30V on each side of coil relative to ground. All transistors and diodes in the circuit check out with junction test. Q904 has weird voltages on it too.
Thank you.
Thank you.
