Northnmonkey
I was stoked to pick this up at the dump the other day.... but of course it's never that easy is it. Through the left channel it sounds really nice, clean faultless. The right channel is totally dead - nothing at all.
I connected the pre amp up to another amp and both channels work perfectly and sound clean, I also swapped all the fuses around and it was still the left channel so the fuses must be good. The issue must be with the left channel in the power amp.
I also noticed that 1 transistor that screws onto the board with the 4 flat metal cap things (BD139) was visibly totally fried. Went to the electronics shop and soldered a new one in tonight thinking that had to be my problem - still dead right channel. I'm pretty amateur at soldering so maybe thats my problem, but I have checked and double checked and my soldering all looks good (ugly but solid enough) and does not look to be any shorts or anything.
Im pretty new to all this electronics so you might have to bear with me a little. I have spent much time on here reading the forums and have tried all the things I can find so far but now I'm all of ideas.... I have a multi meter and a (very) basic idea on electrics.
![20160520_162359[1].jpg 20160520_162359[1].jpg](/forums/data/attachments/611/611144-dbc3a9f409dcc1f99d0ee9563815e23e.jpg?hash=28Op9Ancwf)
![20160525_195152[1].jpg 20160525_195152[1].jpg](/forums/data/attachments/611/611427-cae91e9354b8ada58c762755bcbdddbf.jpg?hash=yukek1S4ra)
![20160525_195200[1].jpg 20160525_195200[1].jpg](/forums/data/attachments/611/611428-678c34dfb6ee337ea68a6a45c9b5544e.jpg?hash=Z4w037buM3)
![20160525_195336[1].jpg 20160525_195336[1].jpg](/forums/data/attachments/611/611430-a3872b872d3f707308dbfa93c558597e.jpg?hash=o4crhy0_cH)
![20160529_174008[1].jpg 20160529_174008[1].jpg](/forums/data/attachments/613/613408-3d8a9775842e21c13ab140609e99efc7.jpg?hash=PYqXdYQuIc)
![20160529_174025[1].jpg 20160529_174025[1].jpg](/forums/data/attachments/613/613409-3844f59169612f43303f4656ba449527.jpg?hash=OET1kWlhL0)
![20160529_174251[1].jpg 20160529_174251[1].jpg](/forums/data/attachments/613/613411-e88c625d6cfc8b539a780bf094f582cf.jpg?hash=6IxiXWz8i1)
