preacherJohn
I need to find a substitute for a 2SK68A in a Kenwood KA 3500 I've been working on. I'll try to post the schematic also. There's one resistor (R58) that gets so hot it begins to smoke. I'm not seeing any shorts on my current limiter, but there's a reason it's turning brown on me and I'm suspecting one or more of the FETs Qd1-Qd4 is bad. The other components in the loop with R58 check out alright. I replaced this resistor once with a 1 watt 100 ohm metal film. I can't keep the unit on long enough to check a voltage as it will burn up pretty quick. I've searched and searched for a replacement for those 2SK68As and all subs that are listed in other threads are discontinued. But I did run across one thread that mentioned an LSK189. I found these at Mouser but they're not cheap. If I have to pay 6.74 ea for 4 of them, so be it; I can't find anything else. Will the LSK189 be a decent substitute for the 2SK68A? Or if there is something else that someone found that fits the bill and is stock where I can order them, I'm all ears. Thanks.
