Hi guys,
I'm way overdue adding to this thread, but for those that are interested, here are the factory specs of the Seas 30WK:
- Size: 12"
- Recommended frequency range: 30-500 Hz in 60 l closed box
- Recommended closed box volume: 45-90 l
- Free air resonance: 18-22 Hz
- Impedance: 8 Ω
- Nominal power: 50 W
- Peak power: 100 W
- Operating power: 3,2 W (96 dB/1 m)
- Characteristic sensitivity: 91 dB
- Flux density: 11000 Gauss
- Gap energy: 570 mWb
- Voice coil diameter: 39 mm
- Voice coil height: 18 mm
- Gap height: 8 mm
- Force factor (BL): 11 Tm
- Piston area: 490 cm²
- Moving mass, incl. air: 70 g
- Diameter: 303 mm
- Mounting depth: 150 mm
- Net weight: 2,4 kg
Also, here are my own T/S measurements for the 8 Ohm version (average of four units dated 43/70):
- Sensitivity (2,83 V, 1 m): 93,1 dB
- BL: 11,2 Tm
- Re: 5,4 Ω
- Zmin: 6,08 Ω
- Zmax: 128,5 Ω
- L1k: 0,73 mH
- L10k: 0,40 mH
- Mms: 49,3 g
- Cms: 1,04 mm/N
- Rms: 1,03 Ns/m
- Fs: 22,3 Hz
- Qms: 6,725
- Qes: 0,298
- Qts: 0,285
- Vas: 347 l
For those who want to build a speaker with these drivers, you should note that they have
very soft rubber suspensions and a center spring/spider of quite small diameter. Therefore, when these woofers approach their maximum mechanical excurdion, the limit is reached rather suddenly. When driven beyond this point, the tiny spider will stretch and deform, often resulting in a voice coil that starts to rub against the steel poles.
For the very same reason, the 30WK should not be used in bass reflex enclosures. While a closed box acts as a pneumatic spring, aiding the suspension in controlling excursion, bass reflex boxes don't: A reflex box will only control excursion near the actual tuning frequency. Above and below this frequency, it is essentially without acoustic resistance.
- H -
