skriefal
Just today I encountered a new, obvious buzzing sound through my speakers when listening to my 2-channel audio system. I've been unable to identify the cause and would appreciate any suggestions.
First, the system:
What I've tried, in order:
The last two tests suggest that there is no problem with the JWN amplifier or the Blueberry pre-amp. But when the two are connected together a buzzing sound appears at the speakers... even with no other inputs or A/C power connected to the pre-amp.
I'll probably be changing the system around in a few weeks, and that may eliminate whatever is causing this issue. But I'd still like to answer what is going on here if I can.
Anyone have any ideas? Thanks!
First, the system:
- Juicy Music Blueberry Extreme (BBX) pre-amp (tubed)
- JWN amplifier (tubed)
- AR-XA turntable
- Denon 2910 CD/SACD/DVD-A player
- SAE tuner
- Polk LSi15 speakers
- Swapped in spare tube set into the JWN amplifier. Buzz remains.
- Swapped in spare 6922 input tube in the Blueberry pre-amp. Buzz remains. I did not swap in a spare 12X4 rectifier or spare phono stage tubes, but I doubt that would help (read on...).
- Swapped interconnects and power cables . Buzz remains. I didn't try different speaker cables, but I doubt that would help (read on...). Buzz remains.
- Swapped speakers. Buzz remains.
- Disconnected all audio inputs from the pre-amp (including one that could have brought in a ground loop from my Dish Network DVR). Only A/C power and the pre-out are connected at this point. Buzz remains.
- Unplugged power cables from the tuner, CD/SACD player, and turntable. Only the JWN amplifier and Blueberry pre-amp are powered at this point. Buzz remains.
- Lifted the A/C ground on both the amp and pre-amp (using "cheater" plugs). Buzz remains.
- Powered the pre-amp from a different A/C outlet (with the help of an extension cord). Buzz remains.
- Unplugged the pre-amp power cable entirely. Buzz remains. At this point the amp was powered and the pre-amp's pre-out was connected to the amp, but all other pre-amp inputs and outputs (including power) were disconnected.
- Tested the JWN amplifier driven by a spare Carver pre-amp. Buzz is gone.
- Tested the Blueberry pre-amp driving a spare amplifier. Buzz is gone.
