Hi!
This just started up that between the two phono inputs and also the tape head input on the selector, a popping noise has turned into (in particular PH1) a motorboating, woofer excursioning event that has scared the pants off me! Also it's only on the left channel
It only happens during the switching and it goes away when you fiddle with the switch and I suppose, re-seat it and there is a slight, but not loud, pop, when turning between these two phono inputs.
Otherwise it's alright...but what to do? The Tannoy Gold, well I can see the cloth on the outside moving so that's alarming...yes I did open her up and clean the contacts on the selector switch and there was a fair amount of dirt there...
What could be causing this?
Note - it's not on anything else...and I have put new phono tubes in to make certain it wasn't either one of them.
Quite frankly - I am a bit freaked out here...
No buzzing or anything else noticable...
