Hello, like the title says i am trying to fix a intermittently unstable Pioneer SA-3000 amp for good, it has one of the following issues at one time or all together: random popping and crackling from speakers even with volume closed and no signal being fed (like a very very dirty record), erratic relay behavior, has burned drivers and its resistors several times, took out one output one time.
currently i am debating whether to replace both 2SA798 with two matched KSA992s in an adapter pcb i am designing currently, or just glue one next to the other side y side and heatshrinked together. or even use a single SMD part (tho the ones ive found as per datasheet are labeled as "general purpose" while the 992s are labeled as audio parts)
anyway i need replacements for:
(Q9) 2SC1914
(Q11) 2SC1885 (tall type)
(Q13) 2SA912 (tall type)
(i belive its called TO-92L ?) and i am afraid using regular 92s because i dont know if they will run hotter than designed
i dont know exactly if they are bad or not, ive already replaced all outputs and all drivers and it worked fine the day i fixed it, the next day after being left alone the crackling popping came back along with erratic relay behavior (bias was fine tho for some reason)
this amp has been repaired by another tech 6-7 times in the last 4-5 years always the same failure mode and symptoms.
so id like to fix this amp once and for all (this will be my 2nd attempt) by shotgunning all remaining transistors in the amp pcb on both channels
As always any help is greatly appreciated
(ive attached part of the schematic with the transistors to be replaced pointed out)
(Q9) 2SC1914
