moinau
Je me Souviens
Hi,
I've acquired a CS-505-1 from a friend a couple days ago.
The TT would not start at the beginning, the switch was stuck.
I put the TT apart, cleaned everything underneath, fixed the switch, had the Ortofon cartridge, the Dual TKS 49 S, with the Dual stylus DN 149 S off the tone arm, cleaned all connections and put everything back together.
Now the problem is: I have normal sound on the left channel and some very very faint sound from the right channel.
and...
There is no strobe light to adjust the speed...
Questions:
1: Is the stylus right channel broken, or
2: are the connections on the cartridge holder broken, or
3: are the connections from the shell broken,
4: do I have to change the whole cartridge with stylus, and if so
5: where can I find this type of cartridge, the Ortofon made Dual TKS S
This cartridge holder is held by one screw located on top of the shell
Also, I would like to lubricate the motor bearing, but it appears to be sealed, am I right???
If I can manage to fix these few hick ups, I will give this TT to one of my son.
Thanks
and...
Questions:
Thanks
