Nathan44
Hi there!
I got an old turntable setup from my dad and I'm trying to get it working again. One of the problems is with the amplifier. Namely the sound from the left channel does either not work or is having trouble creating sound. I already scowered through some forums trying to find a solution, but I wasn't able to realy find a conclusion on it, so I'm hoping someone here can help me clear things up.
It's about the Philips 22AH683 amplifier and these are some of my observations:
-It is the amplifier not something else: I tried different different sources and different output devices
-It is always the left channel, switching the source cables left and right changes nothing and using stereo or mono also has no effect
-Increasing the volume on the amplifier while decreasing the source volume sometimes helps, where it goes from no sound on the left channel, to a distorted sound, to a good sound.
-Using the bass and treble buttons: the lower frequencies are mostly distorted and the higher frequencies are damped.
-Turning the bass and treble potentiometers does not create any crickling sound
-Twisting the volume knob like crazy may help a little with going from no sound to the distorted sound
I mostly read about cleaning/replacing the potentiometers or the relais, or that it might be any condensator. I don't mind replacing any components, but I also don't want to waste money on replacing the wrong ones and eventually still not fixing it. So does anyone have a clear idea of what it could be or am I better off handing it over to a repair shop? Anyway thanks for reading through all that and for any answers
