CoolOhm
Cool Ohm
Hello Fellow AK'ers:
Well I finally went out and got myself a tube amp! I have never heard one before and the curiosity got the better of me. Had my heart set on an Dyna ST-35 but this VTA-70 came up and the price was right... Looking for some opinions and advice prior to powering it up and giving it a listen.
This was allegedly built one year ago by a well reputed tech. in Toronto, but I want to check some things out before I plug it in and try it out. My idea here is to really make sure all is right so that it sounds as good as it can the first time (I want to hear a difference) - if that makes any sense...
So I will check and adjust the bias on the tubes but before I do here are some concerns... Pictures are posted below.
Output Tubes
They are brand new Ruby EL34B-STR. My concern is that googling this tube brings up only discussion from the guitar amp world. Crickets from the audio world. Are these even worth trying given my objective here?
Coupling Caps
The only schematic I can find on this circuit is here. This shows the coupling capacitors as 0.22uF, however inspection of mine shows 0.33uF! Again, are these even worth trying given my objective here? Every one of these amps I see on the net seem to use Russian PIOs in this position. I am not so concerned really about the composition but the value of the 0.33 versus 0.22 is concerning.
Driver Tubes
In Bob Latino's installation manual for this board, the three driver tubes are described as 12AU7 (or 12BH7/5963/5814/6189). However inspection of mine shows three brand spanking new Tung-Sol 6NS7 GTBs. Hmmm. Again, this seems to be a deviation from the design and therefore suspect.
System
I will be using this amp (initially) with my Carver solid state C-1 preamp in my main system which uses some older Heresys with upgraded ALK networks.
Here some pictures below... If you do recommend replacing any of these bits please suggest a source (I prefer Canadian dealers to avoid customs and brokerage issues whenever possible, but this a secondary concern).
Any help much appreciated!
Output Tubes
Coupling Caps
Driver Tubes
System
