Help needed with Klipsch
Can two Klipsch RP-5000Fs and Rotel A11 be combined and sound perfect?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 3 100.0%
  • Total voters
    3
Davashman
I want to add a new Pro-Ject T1 to my music system. There are questions on 2 points. Would be grateful for advice!
Condition: I possess Klipsch 3 Heritage and two RP-5000Fs with an old amplifier.
To the newly added Pro-Ject T1, I want to change the amplifier and either to add speakers or to change them.
Questions:
1) Can my Klipsch and Rotel A11 for example be combined?
2) Should I change my floorstanding speakers for new ones with Dolby Atmos for a better display of vinyl?
3) Or maybe it is better to buy speakers to get a 5:1 system with their own Powergate amplifier?
Thanks in advance!
Yes. they will work well together. Dunno about "perfect". That's subjective and up to your ears.
Can't answer your other questions. Dunno that anyone can.
Your turntable doesn't really have anything to do with your amp EXCEPT a preamp must be in the system. It can be built into the amp (that would be an integrated amp) or a separate preamp or receiver OR built in to the turntable OR use an external phono preamp between your turntable and your amp/receiver.
Your Rotel is an integrated amp which means it has a pre amp and an amp, so the Pro-ject should work just fine.
5.1 system might be fine in an audio/video system, might not.
Check the ohm ratings on the speakers and the amp/receiver to see if you can use all those speakers with your Rotel. If not, you MIGHT be able to use them all with a 5.1 amp/receiver again it depends on the ohm raitings for the speakers and amp/receiver.
