A while back I tried a cartridge with a .33mV output and I felt that it had too much gain when paired with my MC stage. Based on my limited research I think the optimal MC cart for me should have an output of ~.15mV.
I'm also not sure how to calculate the gain of my MC stage. Below are the specs I have, can someone confirm this before I start to look for a cart with such a low output (they do not seem common).
Input Sensitivity & Impedance (at 1kHz)
MC - 0.1mV / 200 Ohms
MM - 2.5mV / 47k Ohms
SNR (short circuit A-network)
MC - 76 dB (-156dBV)
MM - 91 dB
Channel Separation (1kHz, at rated power)
MC - 70dB
MM - 75dB
Maximum Input Capability (at 1kHz 0.01% THD)
MC - 40mV RMS
MM - 330mV RMS
Let me know if there is any other info or spec needed to make the determination.
Thanks in advance.
MM - 91 dB
MC - 70dB
MM - 75dB
MC - 40mV RMS
MM - 330mV RMS
Thanks in advance.
